In modern MMORPG progression, time efficiency is just as important as raw grinding power. In Aion 2, players often struggle to balance real-life schedules with in-game economic growth. Fortunately, the game offers multiple ways to generate Kina, the core currency used for character development, gear enhancement, and market trading.
This guide breaks down the most efficient farming strategies depending on how much time you are willing to invest, from casual 2-hour setups to multi-character optimization.
Understanding the Level 45 Farming Benchmark
The first important milestone for serious farming is reaching level 45 with at least one gear score of five.
Players meeting this requirement can easily join expedition parties and participate in high-value dungeon runs. The reward structure is attractive:
Guaranteed 600,000 Kina per expedition cycle
Additional 14 Selenium (approximately 70k Kina value)
Chance to obtain Wrathful Mind, currently valued around 2 million Kina
Possibility of receiving unique or heroic equipment drops
The real advantage lies in the combination of guaranteed income plus RNG reward potential.
However, achieving this setup is not free with buy Aion 2 Kinah.
Reaching level 45 and upgrading gear score usually requires 12–16 hours of gameplay, which is not realistic for casual players. This is where alternative efficiency strategies become important.
The Bare Minimum Strategy — 2 Hours Start Farming
If you have very limited time, the best entry method is surprisingly simple.
Create a new character
Follow the main quest line for about 2 hours
Unlock the Crow Cave Expedition
Once this is completed, you already have a basic Kina farming character.
Although the income is small compared to high-level farming, the time investment is extremely low.
Expected Weekly Income
Around 500,000 Kina per day
Selling Selenium obtained from runs adds extra value
If all runs are sold:
Approximately 4.3 million Kina per week
This method is ideal for players who treat the game as a side activity.
Conquest Expedition Farming Efficiency
If you are willing to push further, you can aim for full conquest expedition farming.
Direct Level 45 Route
Time investment: 12–15 hours
Weekly income: roughly 6 million Kina
Interestingly, the difference between 2-hour setup farming and full leveling is not extremely large when considering time efficiency.
Players can also utilize:
Seven special shop refills
Seven morph refills using Kina and Odials
With refill optimization:
Weekly income can reach around 6 million Kina
This makes moderate playtime characters surprisingly competitive.
Multi-Character Farming — The Real Power Strategy
The real meta in Kina farming is alt character optimization.
Instead of focusing on a single character, players can create two to three alts.
Three Character Crow Cave Setup
Total playtime: 6–7 hours to establish
Weekly income potential:
Without refills: about 12.9 million Kina per week
However, there is an important mechanic to watch.
Using refills across multiple characters may trigger farming penalties.
The expedition system allows:
Around 55 runs per week across three characters
Using refills after that may reduce efficiency
Therefore, smart resource scheduling is recommended.
Urugu Canyon Expedition — Is It Worth It?
At level 28, players unlock the Urugu Canyon expedition.
Rewards include:
Additional 20 Kina per cube
However, many experienced players avoid this map.
Why?
Large map size increases travel time
Each run may require around 5 minutes
The time-to-reward ratio is generally worse than Crow Cave farming.
For most players, skipping this dungeon is acceptable.
Fire Temple Expedition — The Hybrid Reward Model
At level 35, another farming option opens.
The Fire Temple expedition provides a different reward structure.
Advantages:
Similar Kina income to Crow Cave farming
Drops gold gear items
Gold gear is valuable because it can be used to reroll equipment statistics on main characters.
Disadvantages:
Consumes 30 energy per cube
Selenium drop rate becomes lower
Overall Kina per week may decrease compared to optimized Crow Cave farming
Run count efficiency:
Three alts only need about 36 total runs
This leaves room to add another character or use refills strategically
Endgame Farming — Level 45 and Conquest Dungeon Dominance
Once players reach level 45, advanced expeditions unlock.
At this stage, players transition from exploration dungeons to conquest dungeons.
Single Level 45 Character
Base weekly income:
Around 6 million Kina
With full 14 refills:
Approximately 9.3 million Kina per week
Multi-Alt Endgame Farming
The real economic advantage appears when using multiple characters.
Three Characters Setup
Weekly income:
About 18 million Kina
Full Refill Optimization
Maximum potential:
Less than 28 million Kina per week
This includes:
Expedition rewards
Selenium value
Dungeon drops
Even soulbound heroic or unique items still have utility because they can be used for stat rerolling equipment on other characters.
Eight Character Farming — Hardcore Optimization
Some players push the system to the extreme.
If you have eight characters and avoid refill purchases:
Total runs per week: 72
Penalty threshold: 83 runs
This means:
You can safely farm without triggering heavy diminishing returns.
Estimated income:
Can reach extremely high weekly Kina totals.
However, maintaining eight active farming characters requires significant time management.
Many players jokingly suggest that if you are running this setup, you may need to reconsider your life balance.
Gold Gear Value Beyond Direct Drops
Even if items are soulbound, they still provide economic value.
You can:
Use dropped gear to reroll stats on main equipment
Improve combat efficiency
Reduce long-term upgrade costs
This indirect value is often overlooked but extremely important.
Choosing the Right Farming Strategy
The best farming strategy depends on your real-life schedule.
Available TimeRecommended Strategy
2 hours/dayCrow Cave entry farming
6–7 hours/weekThree-alt expedition farming
12+ hours/weekLevel 45 conquest farming
Hardcore modeEight-character optimization
Casual players should focus on efficiency rather than maximum character count.
The Reality of MMO Economy Farming
At the highest level, farming efficiency is not only about dungeon rewards.
Other factors matter:
Character maintenance time
Travel distance inside maps
Energy refill cost vs reward gain
Market price fluctuation of drops
Spending excessive time grinding may not always produce better real-world value.
Final Thoughts
In Aion 2, Kina farming revolves around balancing progression and time investment.
For most players:
Starting with Crow Cave expedition farming is the safest entry.
Multi-alt character strategy provides the best long-term income with Aion 2 Items.
Level 45 conquest dungeon farming remains the core endgame economy engine.
If you are a casual player, focus on 1–3 characters and optimize run efficiency. If you are a hardcore grinder, multi-character conquest farming can generate impressive weekly currency income.
Ultimately, the best strategy is the one that fits your lifestyle—because even in MMORPGs, time is the most valuable resource.
