Season 2 Reloaded for Call of Duty: Black Ops 7 has shaken up the weapon meta in a major way, especially in Call of Duty: Warzone. With a fresh balance patch introducing buffs and nerfs across multiple weapons, many previously popular loadouts have fallen out of favor while others have risen to the top.
If you're jumping back into Warzone and want to stay competitive, updating your class setups is essential. The new patch has introduced several standout weapons that dominate both close-range fights and long-range engagements. From powerful assault rifles to lightning-fast SMGs, this guide breaks down the top five meta loadouts in Warzone Season 2 Reloaded and explains why they are currently dominating the battlefield Call of Duty Black Ops 7 Bot Lobbies.
Let's dive into the new meta.
1. Peacekeeper MK1-The New Long-Range King
The Peacekeeper MK1 has quickly climbed the rankings to become the number one assault rifle in the Season 2 Reloaded meta. Previously known mostly as a sniper support weapon, recent buffs have transformed it into a deadly long-range option capable of competing with the best rifles in the game.
Recommended Attachments
Optic: Fang Hover Point ELO
Muzzle: Mod Suppressor
Barrel: 25" EAM Heavy Barrel
Magazine: Barrage Extended Mag
Stock: EAM Blitz Fire Stock
This loadout focuses on maximizing recoil control and bullet velocity while maintaining strong mobility. The Fang Hover Point ELO provides a clean sight picture and adds recoil stabilization, making long-range engagements significantly easier.
Meanwhile, the Mod Suppressor increases bullet velocity and damage range while also keeping you off enemy radar when firing. In Warzone, stealth is extremely valuable, especially during late-game rotations.
The 25-inch EAM Heavy Barrel further improves vertical and horizontal recoil control while boosting bullet velocity. Combined with the EAM Blitz Fire Stock, the weapon becomes incredibly stable even during sustained fire.
Finally, the Barrage Extended Mag increases the magazine capacity to 60 rounds, allowing you to eliminate multiple opponents without needing to reload.
Why It's Meta
The Peacekeeper MK1 now offers:
Fast sprint-to-fire speed
Excellent ADS time
Strong movement while aiming
Very manageable recoil
A surprisingly fast time-to-kill
Because of these strengths, the Peacekeeper has transitioned from a secondary option to one of the best long-range assault rifles in Warzone right now.
2. Code 7-The Fastest SMG in the Meta
If you prefer aggressive gameplay, the Code 7 SMG is currently the top-ranked submachine gun in Warzone Season 2 Reloaded. Its extremely fast fire rate and rapid time-to-kill make it perfect for close-quarters fights.
Muzzle: Hawker 9 Brake
Barrel: 13.5" Canes 05 Barrel
Underbarrel: Vast Drift Lock Foregrip
Magazine: Vex Expanse Mag
Fire Mod: Buffer Spring
The Hawker 9 Brake significantly improves recoil control, especially the first shot kick and vertical recoil. This helps maintain accuracy during rapid engagements.
The 13.5-inch Canes barrel increases damage range, making the weapon more viable beyond close quarters. While SMGs typically struggle at medium distance, this attachment helps extend the Code 7's effective range.
The Vast Drift Lock Foregrip improves horizontal recoil control, allowing you to maintain accuracy when spraying enemies during hectic fights.
With the Vex Expanse Magazine, your ammo capacity increases to 50 rounds, which is crucial when fighting multiple enemies in Warzone squads.
Finally, the Buffer Spring fire mod improves both horizontal and vertical recoil control, making the weapon much easier to handle.
Why It's Meta
The Code 7 excels in:
Close-range engagements
High mobility and movement speed
Extremely fast time-to-kill
While it can still challenge enemies at medium range, players should use burst firing for better accuracy.
Overall, the Code 7 is one of the most aggressive SMGs available, perfect for players who enjoy pushing buildings and wiping squads quickly.
3. Maddox RFB-A Balanced Assault Rifle Powerhouse
The Maddox RFB has also benefited significantly from the Season 2 Reloaded balance changes, now sitting as the second-ranked assault rifle in the current meta.
Muzzle: Red Well Shade X Suppressor
Magazine: Mandible Extended Mag
Stock: Migrate MLX Stock
Fire Mod: 5.56 NATO FMJ
This build emphasizes accuracy and sustained damage output.
The Fang Hover Point ELO once again provides excellent visual clarity and recoil stabilization. Meanwhile, the Red Well Shade X Suppressor improves recoil control in multiple directions while also keeping your shots hidden from enemy radar.
The Mandible Extended Magazine boosts capacity to 60 rounds, making the Maddox ideal for squad fights.The Migrate MLX Stock enhances recoil stabilization and adds flinch resistance, which is extremely useful during long-range engagements.
Finally, the 5.56 NATO FMJ fire mod increases:
Damage range
Bullet velocity
Wall penetration
Enemy flinch when hit
Why It's Meta
The Maddox RFB offers a perfect balance between power and mobility. Players can expect:
Fast fire rate
Quick ADS speed
Smooth movement while aiming
Consistent time-to-kill
Although the weapon has moderate recoil, the attachments in this setup make it highly controllable. If you're looking for a versatile rifle that performs well in most situations, the Maddox RFB is a fantastic choice.
4. Ryden 45K-A Deadly Close-Range SMG
Another powerful SMG in the current meta is the Ryden 45K, currently ranked second among submachine guns in Warzone Season 2 Reloaded.
Muzzle: Hawker Series 45
Barrel: 12" Vienna Barrel
Underbarrel: Flow Guard Foregrip
Magazine: Forward Breach Mag
Rear Grip: Eruption Grip
The Hawker Series 45 improves vertical recoil control, helping maintain accuracy during rapid fire.
The 12-inch Vienna Barrel increases damage range, giving the weapon a more consistent time-to-kill in close and medium-range fights.
The Flow Guard Foregrip improves horizontal recoil while also increasing sprint and movement speed, which is extremely valuable for aggressive players.
The Forward Breach Magazine boosts ammo capacity to 50 rounds, ensuring you can handle multiple enemies without constant reloading.
Finally, the Eruption Grip improves several key mobility stats, including:
Aim-down-sight speed
Slide-to-fire speed
Dive-to-fire speed
Jump ADS speed
Why It's Meta
The Ryden 45K stands out due to its:
Excellent mobility
Fast fire rate
Competitive time-to-kill
Strong recoil control
This weapon excels in close-range engagements and can even hold its own at medium distances if used carefully.
In Warzone, where mobility and fast reactions are crucial, the Ryden 45K is an incredibly reliable secondary weapon.
5. M15 Mod Zero-Still Meta Despite Nerfs
Even after receiving nerfs in the Season 2 Reloaded update, the M15 Mod Zero remains one of the most reliable assault rifles in Warzone.
Muzzle: Monolith Suppressor
Magazine: Bowen Bullwark Mag
Stock: Bowen Lynchpin Stock
Barrel: 16" Reticulated Barrel
The Fang Hover Point ELO again provides strong recoil stabilization and a clear sight picture.
The Monolith Suppressor improves damage range and bullet velocity while keeping you hidden from the minimap.
The Bowen Bullwark Magazine increases ammo capacity to 60 rounds, ensuring sustained fire during squad fights.
The Bowen Lynchpin Stock significantly improves vertical and horizontal recoil control, making the weapon much easier to handle during longer engagements.
Finally, the 16-inch Reticulated Barrel further improves recoil control and bullet velocity.
Why It's Still Meta
Despite the nerf, the M15 Mod Zero still delivers:
Fast fire rate
Quick ADS speed
Solid mobility
Reliable medium-range performance
For longer-range fights, players should use burst firing instead of holding the trigger continuously. This technique helps maintain accuracy and improves overall time-to-kill.
Best Secondary Weapons and Perks
Most players pair an assault rifle with an SMG to cover both long-range and close-range combat scenarios. This combination provides the flexibility needed to survive across the various environments in Warzone.
Recommended Equipment
Lethal: Semtex
Tactical: Smoke Grenade
Melee: Knife
Recommended Perks
Scavenger-Keeps your ammo supplies stocked during extended fights
Sprinter-Improves mobility and repositioning speed
Adaptive-Provides extra versatility depending on the situation
These perks complement aggressive playstyles while ensuring you stay well-equipped during intense matches.
Final Thoughts
The Season 2 Reloaded update has significantly changed the weapon landscape in Warzone. Some familiar weapons have fallen out of the spotlight, while others-like the Peacekeeper MK1 and Code 7-have emerged as dominant options cheap Bot Lobby BO7.
To recap, the top five meta loadouts right now are:
1.Peacekeeper MK1 (Best Assault Rifle)
2.Code 7 (Best SMG)
3.Maddox RFB (Versatile AR)
4.Ryden 45K (Aggressive SMG)
5.M15 Mod Zero (Reliable AR)
Each of these weapons offers a unique playstyle and excels in different combat scenarios. Whether you prefer long-range control or aggressive close-quarters combat, these loadouts will give you a major advantage in Warzone Season 2 Reloaded.
If you're looking to dominate matches and secure more wins, updating your loadouts to match the current meta is absolutely essential. Try out these builds, adjust them to your personal playstyle, and you'll be well on your way to climbing the Warzone ranks.
