ZBrush.de - Forum - Sonstiges - off-topic
Alles was man einfach mal posten will
ZBrush 4R2b wird ausgeliefert
24.01.2012 09:48   (Vor 5349 Tagen) 7490 Aufrufe 11 Antworten
So heute ist es endlich soweit. Pixologic liefert ZBrush 4R2b aus.
Den Updater gibt es im Pixologic Download Center.
http://www.pixologic.com/zbrush/downloadcenter/
Mehr dazu in der ZBrush Central.
http://www.zbrushcentral.com/showthread.php?165512
ZBrush4 R2b is a free update for all registered ZBrush users.
For anyone who already has ZBrush 4R2 installed, an Updater is available now in the Pixologic Download Center. Please carefully read the instructions that are provided with the Updater.
If you cannot install version 4R2 (because you never upgraded to it or did not save your installer), you will not be able to use the Updater. Instead, please submit a ticket in the Support Center. Choose the "Upgrades" department when prompted. Be sure to include any information that can help us locate your account so that we can assist you promptly.
New purchasers of ZBrush will receive version 4R2b directly and will not need to update.
Floating license customers will receive an email with special upgrade instructions before the end of January.
:o in 10 minuten isses vollbracht :cool:
zlatantoon
zlatantoon
Hallo Leute,
eine frage, bei step 2:
__________________________________________________________________________________
Step 2: Make a Backup
Simply make a copy of your ZBrush 4R2 folder. That way you will be able to easily
restore your custom UI and any custom brushes or other items that might be overwritten by the Updater.
______________________________________________________________________________________
Muss ich nach der deaktivieren von ZB R2 denn ordner mit allem was drin ist noch mall kopieren und dort das update ausführen?
Danke!!
Zlatan
hauptsache du kopierst den ordner vor dem update.
ob vor oder nach deaktivierung is latte
mfg
som80
So wie ich das verstehe ist es so, das Update überschreibt ALLE, oder zumindest fast alle Datein und Ordner im Installationverzeichnis von 4R2. Um deine persönlichen Einstellungen zu sichern, (eigene Pinsel, Farbschema, Shortcuts, Custom UI usw.) sollte man alle Ordner aus 4R2 kopieren, einfügen. (anderes Verzeichnis, Laufwerk oder sonst was). Deine eigenen Sachen bekommst du zurück, falls überschrieben, oder irgend ein anderer Fehler bei der Installation des Updates vorkommen sollte, indem du die einzelnen Dateien, Material, Custom UI usw. wieder zurück kopierst. Das sind aber reine Sicherheitsmaßnahmen. falls.....
Sollte alles funktionieren OK, falls etwas fehlt (Custom UI, Shortcuts, Brushes...) einfach aus den Ordnern kopieren und einfügen.
hat jemand von euch seit dem update schon mal "move elastic" erfolgreich an einem hipoly model benutzt?
also ohne lag?
mfg
som80
zlatantoon
zlatantoon
Cool :)
Werde am WE instalieren. :P
Danke! :)
da_marc
da_marc
funktioniert prima, bis auf´s noise plug (unter surface).liegt anscheinend am 64 bit
da_marc schriebliegt anscheinend am 64 bit
wieso 64bit? kann zbrush doch garnicht!?
r2 konnte das übrigens auch nicht also warum sollte das was ändern?
und das noisemaker nicht funktioniert, weil nicht vorhanden, ist kein geheimnis;)
mfg
som80
Wenn ich unter Surface gehe und auf Edit drücke steht da was mit NoiseMaker.
Die haben doch einiges gemacht. Das Plugin ist noch nicht integriert, aber in der LightBox unter NoiseMaker ist einiges zu finden. Doppelclick und sehen wie es aussieht.
da_marc
da_marc
das zb kein 64 bit is wusst ich, aber mir war so als hätt ich ma in nem tut geseshen wie einer das plug in genutzt hat (roboter mit tarnmuster find ich aber leider nich mehr), dachte deshalb das es auf 64 bit nich läuft.aber danke für die antworten!
das mit dem tarnmuster bekommst du mit ganz normalem surface noise hin.
stärke auf 0, color blend auf 1 und mit größe und noise curve rumspielen
Insgesamt 12 Beiträge
